Too many problems with stardock products. :(
Windowsfx doing stupid things. When I want to apply the transition and animation effect to all windows (not just "small" ones), they always mix up the window size (it will be hell of a small you can onyl see the three upper-right buttons and you have to resize the window to see anything at all), OR the icon will be messed up, the toolbars will be moved around, etc...
So, if I don't turn on the function "Only fade small windows" for example, only then I experience these kind of problems...
The windows are flashing a few seconds before I can "touch" them (and the above issue will happen).
And no, this is definitelly NOT A PERFORMANCE ISSUE. An 3.2Ghz AMD, 512MB DDR400 and a TI4200 with 64MB of ram should be more than enough to handle any kind of resolutions, agreed?
Now... Should I have any questions or it's pointless to ask?
When will they fix this, who got some info about some fix, etc...
Thanks...
P.S.: Ohh, and I experiencing the same issues at my work pc too at workplace, so I can reproduce the problems anytime.
3,071 views 4 replies
Hmm, as far as I can see You have problems with ONE Stardock product, right ?
ONE stardock product in TWO threads.
Has anger issues also. Most people relate the problem and wait for advice, planetHope has already lost hope in the situation. Makes people less inclined to help I would say,
Powered by SkinBrowser!
