clearone 2 windowblind problem..help.
hi all, i have the lastest paid wb. i have clearone and clearone 2 wb by evgen. my fonts [letters] are purple ish color. what can i do. the wb is on deviantart. the rest of my blinds are fine.....thank you...
1,613 views 2 replies
I've always had the same problem with that theme. I haven't tried changing the fonts yet with the new WB 6 (I'm using the Beta now) but, since you've reminded me of this little problem, it's worth a try. Give it a try, it might work.
*edit* Tried some font changes and it fixed some problems. Evgen used some special effects on fonts (shadows and outlining). Turning off the special effects with WB 6 helped clear up some font problems. ClearONE2 still doesn't work right with DX loaded though. Oh well.
