running system tray and running task dock
question
can i add both the system tray dock and the running task dock.
because im going to hide the taskbar.
2,632 views 4 replies
Yes , but depending on how many icons will show I use 2 separate docks to do this. I personally have 1 dock that I constantly have running tasks showing and a second dock that I only show the taskbar on when I need it. You can also choose which side of the dock that you want them to show.
Found a link in the beginners forum
WWW Link
* Note that I use Objectdock Plus & I don't know if its available in the free version.
I think that once you get used to hiding the taskbar you won't go back
**** You can always access the Windows start menu by pressing the *Windows* key on your keyboard.
It's My Secret
I read the tutorial from the link above, and it talks about when you hide the taskbar, the open application window moves down to cover that space - but I'm having the opposite problem. I want my application window to cover that space, but it does not. Should it do that automatically? And can I make it do it since it isn't doing it on it's own??
right click your taskbar (or start) = properties - taskbar tab - uncheck keep on top
Thanks Bichur....I knew it would be some (stooopid) little thing that I'd overlooked! (kept looking in OD for the answer!)
