running win7 32-bit - windows7 normal right-click
Need a computer smart person for this one ...
The Problem:
just installed the Adobe Master Suite 4 - which includes Acrobat 9 ( Acrobat 9 IS INSTALLED )...
but now whenever I right-click on an item - folder - shortcut on my desktop ... a pop-up comes up
trying to install Acrobat 9 .... I hit cancel and it goes to a regular rick-click menu - then it might stay
that way for a while - then the install shows up again later - it also does this sometimes now when
Im in a folder not just the desktop ......
I tried installing right-click(stardock) to see if it would change the settings and fix the problem
but that didn't work ...
So anyone out there smart enough to tell me how I can reset my right-click and fix this problem ?
Thanks for any help .... Az
